Garmin Nuvi 2557LMT Speaker Replacement
  1. Garmin Nuvi 2557LMT Speaker Replacement, Garmin Nuvi 2557LMT Disassembly: step 1, image 1 of 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Speaker Replacement: step 2, image 1 of 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Speaker Replacement: step 3, image 1 of 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Speaker Replacement: step 4, image 1 of 2 Garmin Nuvi 2557LMT Speaker Replacement: step 4, image 2 of 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Speaker Replacement, Speaker: step 5, image 1 of 1
    • Using a plastic opening tool, wedge the speaker from the device.
    • Don't pull it out of the device too far. It is still connected to the motherboard wire.
  6. Garmin Nuvi 2557LMT Speaker Replacement: step 6, image 1 of 1
    • Using a soldering iron, desolder the wire connection between the speaker and the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 175
