Garmin Nuvi 1390LMT Battery Replacement
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: step 1, image 1 of 1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: step 2, image 1 of 2 Garmin Nuvi 1390LMT Battery Replacement: step 2, image 2 of 2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: step 3, image 1 of 1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: step 4, image 1 of 2 Garmin Nuvi 1390LMT Battery Replacement: step 4, image 2 of 2
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: step 5, image 1 of 1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: step 6, image 1 of 2 Garmin Nuvi 1390LMT Battery Replacement: step 6, image 2 of 2
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: step 7, image 1 of 1
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: step 8, image 1 of 2 Garmin Nuvi 1390LMT Battery Replacement: step 8, image 2 of 2
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
Finish Line
3 other people completed this guide.
Trey Ulsh
537 Reputation
3 Guides authored
Montana Tech, Team 10-4, Shirk Fall 2015 Member of Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
5 Members
3 Guides authored
One Comment
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 3,770
