Garmin GPSmap 60CSx Gasket Replacement
  1. Garmin GPSmap 60CSx Gasket Replacement, Back Cover and AA Batteries: step 1, image 1 of 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Gasket Replacement: step 2, image 1 of 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Gasket Replacement: step 3, image 1 of 2 Garmin GPSmap 60CSx Gasket Replacement: step 3, image 2 of 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Gasket Replacement, Gasket: step 4, image 1 of 2 Garmin GPSmap 60CSx Gasket Replacement, Gasket: step 4, image 2 of 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Separate the back panel from the front.
  5. Garmin GPSmap 60CSx Gasket Replacement: step 5, image 1 of 2 Garmin GPSmap 60CSx Gasket Replacement: step 5, image 2 of 2
    • Remove the gasket.
    • Be careful to make sure the gasket is aligned correctly to ensure it is water proof.
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 1,655
