Garmin Fenix 3 HR Motherboard Replacement
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: step 1, image 1 of 2 Garmin Fenix 3 HR Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: step 2, image 1 of 2 Garmin Fenix 3 HR Motherboard Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: step 4, image 1 of 2 Garmin Fenix 3 HR Motherboard Replacement: step 4, image 2 of 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: step 5, image 1 of 1
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: step 6, image 1 of 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: step 7, image 1 of 1
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: step 8, image 1 of 1
    • Now attach battery to new motherboard and reassemble.
5 other people completed this guide.
Jacob Smiley
277 Reputation
1 Guide authored
IUPUI, Team S1-G6, Harley Spring 2018 Member of IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 Members
4 Guides authored
2 Comments
And where would one source replacement motherboard?
jonathan.hatchuel - Reply
donde puedo encontras placa.madre reeemplazo????
luis zavala - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 27
All Time: 4,794
