Garmin Drive 60LM Motherboard Replacement
  1. Garmin Drive 60LM Motherboard Replacement, Motherboard: step 1, image 1 of 2 Garmin Drive 60LM Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Motherboard Replacement: step 2, image 1 of 3 Garmin Drive 60LM Motherboard Replacement: step 2, image 2 of 3 Garmin Drive 60LM Motherboard Replacement: step 2, image 3 of 3
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Motherboard Replacement: step 3, image 1 of 3 Garmin Drive 60LM Motherboard Replacement: step 3, image 2 of 3 Garmin Drive 60LM Motherboard Replacement: step 3, image 3 of 3
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
  4. Garmin Drive 60LM Motherboard Replacement: step 4, image 1 of 2 Garmin Drive 60LM Motherboard Replacement: step 4, image 2 of 2
    • Using the T4 Torx screwdriver, unscrew the four screws (1/2 cm, 5mm) from the motherboard.
    • Then, lift the motherboard out of its position.
  5. Garmin Drive 60LM Motherboard Replacement: step 5, image 1 of 2 Garmin Drive 60LM Motherboard Replacement: step 5, image 2 of 2
    • Flip the motherboard over towards the right.
    • Then, carefully disconnect the two sets of wires that are connected to the battery and the speaker using your fingers.
    • Remove the motherboard.
Andy Flores
238 Reputation
2 Guides authored
Baylor, Team 3-3, Whitney Spring 2017 Member of Baylor, Team 3-3, Whitney Spring 2017
BU-WHITNEY-S17S3G3
4 Members
3 Guides authored
2 Comments
Bonjour, ou trouver la carte mère ?
Hello, where can I find the motherboard?
th.lamouroux - Reply
i lost the screws while replacing the batterry. where do ifind the screws
Carolyn Mock - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 26
All Time: 1,343
