Garmin Dezl 760LMT Motherboard Replacement
  1. Garmin Dezl 760LMT Motherboard Replacement, Back Panel: step 1, image 1 of 2 Garmin Dezl 760LMT Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Motherboard Replacement: step 2, image 1 of 3 Garmin Dezl 760LMT Motherboard Replacement: step 2, image 2 of 3 Garmin Dezl 760LMT Motherboard Replacement: step 2, image 3 of 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Motherboard Replacement: step 3, image 1 of 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: step 4, image 1 of 2 Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: step 4, image 2 of 2
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Motherboard Replacement: step 5, image 1 of 2 Garmin Dezl 760LMT Motherboard Replacement: step 5, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Motherboard Replacement, Motherboard: step 6, image 1 of 2 Garmin Dezl 760LMT Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Using a Torx T5 screwdriver, unscrew the six 5mm screws on the motherboard.
  7. Garmin Dezl 760LMT Motherboard Replacement: step 7, image 1 of 3 Garmin Dezl 760LMT Motherboard Replacement: step 7, image 2 of 3 Garmin Dezl 760LMT Motherboard Replacement: step 7, image 3 of 3
    • Grasp each of the three wires near where it is attached to the motherboard. Lift them upward to detach them.
    • Lift the motherboard from the device.
Ryan Williams
763 Reputation
6 Guides authored
USF Tampa, Team 4-2, Passmore Fall 2016 Member of USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Members
6 Guides authored
2 Comments
i realy appreciate the video but please tell me where can i find buy the motherboard or others parts for my gps rv-760
Thank you
Pierre Delisle
Québec
Canada
Pierre Delisle - Reply
Is it possible to buy the ribbon cable from the screen to the mother board, and what’s the procedure to replace it on the display ? Thanks
Kiki B - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 16
All Time: 2,850
