Gardena EasyCut Dismantling upper part
  1. Gardena EasyCut Dismantling upper part, Remove the red ring: step 1, image 1 of 2 Gardena EasyCut Dismantling upper part, Remove the red ring: step 1, image 2 of 2
    • Insert a needle into the small hole
    • At the same time pull on the metal part, take it out.
    • Then pull the red ring to remove it
  2. Gardena EasyCut Dismantling upper part, Undo all the screws and separate it in 2: step 2, image 1 of 3 Gardena EasyCut Dismantling upper part, Undo all the screws and separate it in 2: step 2, image 2 of 3 Gardena EasyCut Dismantling upper part, Undo all the screws and separate it in 2: step 2, image 3 of 3
    • Remove all the screws,
    • including the 2 hidden under the black plastic handle
    • Be careful the springs will easily escape
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Bossard Nicolas
1,197 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 63
All Time: 371
