Gardena EasyCut 9823 disassembly of lower part
  1. Gardena EasyCut 9823 disassembly of lower part, Gardena EasyCut 9823 disassembly of lower part: step 1, image 1 of 1
    • Unscrew the three visible screws, surrounded in red in picture.
  2. Gardena EasyCut 9823 disassembly of lower part: step 2, image 1 of 1
    • Remove the two black covers. Frankly, there is no click system.
  3. Gardena EasyCut 9823 disassembly of lower part: step 3, image 1 of 1
    • Remove black protection against grass. Do that by rotating it. Rotation is blocked at two places that you can press with a thin screwdriver.
  4. Gardena EasyCut 9823 disassembly of lower part: step 4, image 1 of 3 Gardena EasyCut 9823 disassembly of lower part: step 4, image 2 of 3 Gardena EasyCut 9823 disassembly of lower part: step 4, image 3 of 3
    • Remove the 6 screws now visible in the blue part. Open it in two parts.
  5. Gardena EasyCut 9823 disassembly of lower part: step 5, image 1 of 1
    • Pull out white block and engine. Then split white block in two by pulling at the arrow place on provided picture.
  6. Gardena EasyCut 9823 disassembly of lower part: step 6, image 1 of 1
    • Clean, fix and re-protect damaged connector.
In order to reassemble your device, please follow instructions in reverse order.
3 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Bossard Nicolas
1,197 Reputation
6 Guides authored
6 Comments
Thanks a lot! My trimmer had the exact same problem.
trrttsch - Reply
Das gleiche Problem bei 2 Trimmern. Danke, die Anleitung hat sehr geholfen!
Martin Kammerhofer - Reply
Ich hatte das gleiche Problem: ein Draht abgebrochen.
Dannk dieser professionellen Anleitung funktioniert der Rasentrimmer wieder. Ohne diese hätte ich es nicht geschafft, den Grasfangteller zu demontieren
Manfred Schierhuber - Reply
Wo bekommt man einen neuen Motor her
Ulli Leistner - Reply
Da müssen Sie sich wohl an den Hersteller wenden!
Past 24 Hours: 25
Past 7 Days: 128
Past 30 Days: 468
All Time: 7,832
