GameSir T4 Pro Charging Port Replacement
  1. GameSir T4 Pro Charging Port Replacement, Battery: step 1, image 1 of 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Charging Port Replacement: step 2, image 1 of 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Charging Port Replacement: step 3, image 1 of 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Charging Port Replacement: step 4, image 1 of 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Charging Port Replacement, Charging Port: step 5, image 1 of 2 GameSir T4 Pro Charging Port Replacement, Charging Port: step 5, image 2 of 2
    • Use the needle nose pliers to remove the plastic connection from the motherboard.
    • You may hold the wires for stability, but do not tug on the wires.
  6. GameSir T4 Pro Charging Port Replacement: step 6, image 1 of 2 GameSir T4 Pro Charging Port Replacement: step 6, image 2 of 2
    • Remove the two 5mm screws on the charging port and take out the old charging port.
  7. GameSir T4 Pro Charging Port Replacement: step 7, image 1 of 2 GameSir T4 Pro Charging Port Replacement: step 7, image 2 of 2
    • Put your new compatible charging port in place.
    • Make sure to screw in the 5mm screws into your new charing port
One Comment
Where i can buy the charging port? Some buttons isnt working so when i was trying to solve the problem with contact cleaner i ended up breaking the soldered connection
Eron Araújo - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 42
All Time: 811
