Game Boy Cartridge Battery Replacement
  1. Game Boy Cartridge Battery Replacement, Battery: step 1, image 1 of 2 Game Boy Cartridge Battery Replacement, Battery: step 1, image 2 of 2
    • Use the screwdriver to loosen the screw on the cartridge.
  2. Game Boy Cartridge Battery Replacement: step 2, image 1 of 1
    • Switch on your multimeter and select the Voltage (V) mode. Then, test the voltage of the battery in the cartridge.
  3. Game Boy Cartridge Battery Replacement: step 3, image 1 of 1
    • Apply some of the flux paste to help desolder the soldered areas on the battery.
  4. Game Boy Cartridge Battery Replacement: step 4, image 1 of 1
    • Be careful when handling a fully heated soldering iron, as it can burn you.
    • Use the soldering iron once it heats up fully. Then, heat up the soldered areas with the iron.
  5. Game Boy Cartridge Battery Replacement: step 5, image 1 of 2 Game Boy Cartridge Battery Replacement: step 5, image 2 of 2
    • Pick up the solder with the desoldering braid.
  6. Game Boy Cartridge Battery Replacement: step 6, image 1 of 1
    • Wipe off any excess flux paste.
    • The flux paste can damage the circuit board if not removed completely or spread to other areas on the circuit board.
  7. Game Boy Cartridge Battery Replacement: step 7, image 1 of 2 Game Boy Cartridge Battery Replacement: step 7, image 2 of 2
    • Make sure to align the battery's positive side where the positive indicator is and the negative side where the negative indicator is.
    • Use the soldering iron and soldering wire to solder both sides of the battery into place.
  8. Game Boy Cartridge Battery Replacement: step 8, image 1 of 1
    • The battery has to have at least 1.5V. If the multimeter reads a negative value, then most likely, the terminals are placed opposite, so switch them around and check the resulting value once more.
  9. Game Boy Cartridge Battery Replacement: step 9, image 1 of 2 Game Boy Cartridge Battery Replacement: step 9, image 2 of 2
    • Align the cartridge and the circuit board.
    • Then tighten the screw to secure the cartridge into place.
To reassemble your game cartridge, follow step 9.
Jose Ayala
220 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 225
All Time: 1,187
