GE A1050 LCD Replacement
  1. GE A1050 LCD Replacement, LCD: step 1, image 1 of 3 GE A1050 LCD Replacement, LCD: step 1, image 2 of 3 GE A1050 LCD Replacement, LCD: step 1, image 3 of 3
    • Remove the batteries, hand strap, and memory card if so equipped.
    • Remove the two Phillips screws from the bottom.
    • Remove the two Phillips screws from the left side.
  2. GE A1050 LCD Replacement: step 2, image 1 of 3 GE A1050 LCD Replacement: step 2, image 2 of 3 GE A1050 LCD Replacement: step 2, image 3 of 3
    • Remove the two screws from the right side.
    • The two screws from the left side are shorter than the ones from the right. Keep those separated.
    • Start splitting the case from the battery compartment to the sides. No special tool is needed to split the case.
  3. GE A1050 LCD Replacement: step 3, image 1 of 3 GE A1050 LCD Replacement: step 3, image 2 of 3 GE A1050 LCD Replacement: step 3, image 3 of 3
    • Do not remove the back side of the case, just flip it over. The speaker is connected by wires to the main body, but positioned in the back case.
    • Flip the LCD to the bottom. You can not yet remove it, because it is still attached to the board.
    • The LCD cable is held into the connector via some compression clips. Move both ends carefully away from the connector, toward the LCD.
    • The clips only move about an 1/8 of an inch. Be careful not to use too much force.
  4. GE A1050 LCD Replacement: step 4, image 1 of 1
    • After exchanging the LCD for a new one, and after reassembling your camera, you should have a working LCD.
oldturkey03
784,869 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
574 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 1,764
