GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement
  1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: step 1, image 1 of 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: step 1, image 2 of 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: step 1, image 3 of 3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: step 2, image 1 of 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: step 2, image 2 of 2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: step 3, image 1 of 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: step 3, image 2 of 2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, LCD Cover: step 4, image 1 of 1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: step 5, image 1 of 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: step 5, image 2 of 2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: step 6, image 1 of 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: step 6, image 2 of 2
    • Grip the speaker.
    • Lift the speaker from the holder.
    • Turn the speaker over.
  7. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: step 7, image 1 of 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: step 7, image 2 of 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: step 7, image 3 of 3
    • The red wire is the + and the tan wire is the -. These wires are connected with solder.
    • Apply the hot soldering iron tip to the speaker connection solder.
    • Pull the speaker away from the wires.
  8. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: step 8, image 1 of 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: step 8, image 2 of 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: step 8, image 3 of 3
    • Attach a new 65 mm speaker, model #115048352530, with the wire connectors. Match the red wire to the + and the tan wire to the -.
    • Solder the wires to connect. Let the solder cool.
    • Reverse Step 6 to insert the new speaker in holder.
Dominick Giguere
848 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 28
All Time: 1,620
