GATEWAY ML6720 Wireless Card Replacement
  1. GATEWAY ML6720 Wireless Card Replacement, Wireless Card: step 1, image 1 of 1
    • Flip the laptop upside-down.
  2. GATEWAY ML6720 Wireless Card Replacement: step 2, image 1 of 2 GATEWAY ML6720 Wireless Card Replacement: step 2, image 2 of 2
    • Locate the wireless card cover, found on the middle-left section of the laptop as shown.
  3. GATEWAY ML6720 Wireless Card Replacement: step 3, image 1 of 2 GATEWAY ML6720 Wireless Card Replacement: step 3, image 2 of 2
    • Using the 1.5 mm Flathead Screwdriver, remove the cover screw at the top of the wireless card's cover plate.
  4. GATEWAY ML6720 Wireless Card Replacement: step 4, image 1 of 1
    • Pull the wireless card's cover plate up and off to reveal the card as shown.
  5. GATEWAY ML6720 Wireless Card Replacement: step 5, image 1 of 1
    • Remove the two wires connected to the wireless card.
  6. GATEWAY ML6720 Wireless Card Replacement: step 6, image 1 of 2 GATEWAY ML6720 Wireless Card Replacement: step 6, image 2 of 2
    Tool used on this step:
    Flathead 1.5 mm Screwdriver
    $5.49
    Buy
    • Using the 1.5 mm Flathead Screwdriver, remove the two screws at the top left and right corners of the wireless card.
    • Slide the wireless card up and out of the compartment.
Nathan Da Silva
401 Reputation
4 Guides authored
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 9
All Time: 233
