GATEWAY ML6720 Battery Replacement
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Battery Replacement: step 2, image 1 of 1
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Battery Replacement: step 3, image 1 of 2 GATEWAY ML6720 Battery Replacement: step 3, image 2 of 2
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Battery Replacement: step 4, image 1 of 2 GATEWAY ML6720 Battery Replacement: step 4, image 2 of 2
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Battery Replacement: step 5, image 1 of 2 GATEWAY ML6720 Battery Replacement: step 5, image 2 of 2
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
Nathan Da Silva
401 Reputation
4 Guides authored
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 293
