Fujtsu Lifebook Model A6110 Battery Replacement
  1. Fujtsu Lifebook Model A6110 Battery Replacement, Battery: step 1, image 1 of 2 Fujtsu Lifebook Model A6110 Battery Replacement, Battery: step 1, image 2 of 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Battery Replacement: step 2, image 1 of 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
Alvin Thamrin
132 Reputation
1 Guide authored
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 459
