Fujitsu Lifebook E556 Keyboard Replacement
  1. Fujitsu Lifebook E556 Keyboard Replacement, Removing Battery: step 1, image 1 of 1
    • Remove battery:
    • 1. Pull down and hold that little tab.
    • 2. Move left that slider.
    • 3. Pull up to remove battery from laptop.
  2. Fujitsu Lifebook E556 Keyboard Replacement, Removing Screws: step 2, image 1 of 2 Fujitsu Lifebook E556 Keyboard Replacement, Removing Screws: step 2, image 2 of 2
    • Remove screws marked in white and red circles.
    • Note: those in red circles are holding the keyboard and are different than those in white circles. Don't mix them!
  3. Fujitsu Lifebook E556 Keyboard Replacement, Removing plastic bar: step 3, image 1 of 2 Fujitsu Lifebook E556 Keyboard Replacement, Removing plastic bar: step 3, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Put a plastic tool (plastic card, spudger or guitar pick) between that bar and the rest of case (in places marked by arrows). It's holding only on clips- gentle pry until it breaks free.
    • When either of sides are free, pry that tab from behind (area marked by red rectangle, but from the back of the laptop - image very difficult to take).
  4. Fujitsu Lifebook E556 Keyboard Replacement, Removing Keyboard: step 4, image 1 of 2 Fujitsu Lifebook E556 Keyboard Replacement, Removing Keyboard: step 4, image 2 of 2
    • Now, keyboard can be lifted, but it still connected to the motherboard. Gently pull it up.
    • When in horizontal position, you will see keyboard connector on the left. Pull the tabs out (1) then pull the flex cable out too (2).
    • Keyboard is now free.
MichaƂ Kurda
866 Reputation
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 59
All Time: 392
