Fossil Speedway Watch TI-5061 Time Setting Dial Replacement
  1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: step 1, image 1 of 3 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: step 1, image 2 of 3 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: step 1, image 3 of 3
    • Keep clasp in open position.
    • Push one of the spring-loaded pins out of the hole with a Push-pin.
    • Wiggle watch band and clasp till free from each other.
  2. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Back: step 2, image 1 of 1
    • Fit the blades of a pair of scissors into the grooves of the screw back.
    • Twist the screw back counter clockwise with the scissors.
    • Once the back is loose enough, you can use your fingers to twist it off.
  3. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: step 3, image 1 of 2 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: step 3, image 2 of 2
    • Press the release button for the Time Setting Dial using a thin pin.
  4. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: step 4, image 1 of 2 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: step 4, image 2 of 2
    • Pull the dial out gently with fingers.
2 other people completed this guide.
Julia List
5,625 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 1,176
