first image
Add Note Edit Step 9  ¶
  • We're inside!
  • Disassembling this laptop is reminiscent of the old PowerBook G4 Titanium models, and very similar to the MacBook Air.
  • You remove the bottom plate, and everything is screwed into the upper case. The case is now Apple's custom-machined unibody enclosure.
  • The interior is cleaner and flows together better than the previous Pro.
  • Cable routing from various parts of the case to the logic board is simpler in this than the new MacBook because Apple had more room to play with.
first image
Add Note Edit Step 10  ¶
  • Removing the two 1 GB DIMMs. These chips are a new RAM type for Apple, 1066 MHz DDR3 SDRAM.
  • Apple claims this machine maxes out at 4GB RAM, but the Montevina chipset appears to support up to 8GB.
  • Shameless plug: You can upgrade your existing MacBook or MacBook Pro to 4 GB. We'll also be offering the RAM for the new Unibody machines in the near future.
first image
Add Note Edit Step 11  ¶
  • We're going to remove the optical drive next.
  • Disconnect these two connectors.
first image
Add Note Edit Step 12  ¶
  • To free the Superdrive, remove the following 3 screws
first image
Add Note Edit Step 13  ¶
  • Liberating the optical drive from the confines of this beautiful machine.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 14  ¶
  • The optical drive is SATA for the first time. Panasonic model #UJ878A.
  • The superdrive in the last model was ATA, model #UJ857.
  • You can see the different connectors in the middle picture. The new, SATA connector is on top.
  • The rightmost photo is a shot of the new drive label.
first image
Add Note Edit Step 15  ¶
  • Pry the two fan connectors up off their sockets on the logic board.
  • Remove the following 6 screws:
    • Three 3.1 mm Philips screws.
    • Three 3.7 mm Philips screws.
first image
Add Note Edit Step 16  ¶
  • Removing the two cooling fans.
  • Apple has long used a unique fan design with a high number of fan blades. This allows them to achieve moderate airflow with low RPM. The slower the fan spins, the quieter it is.
Next » « Previous
Required Tools
Anti-Static Wrist Strap
$7.95 · 17 in stock
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
$7.95 · 17 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
Notes Add Note Notes are offturn on
