Fender Jazz Bass Strings Replacement
  1. Fender Jazz Bass Strings Replacement, Strings: step 1, image 1 of 1
    • Loosen the strings by turning the tuning pegs.
  2. Fender Jazz Bass Strings Replacement: step 2, image 1 of 1
    • Once the strings are loose, remove them from the tuning pegs.
    • If you prefer, you can also cut the strings off.
  3. Fender Jazz Bass Strings Replacement: step 3, image 1 of 2 Fender Jazz Bass Strings Replacement: step 3, image 2 of 2
    • Reach under the bridge to pull out the end of each string.
  4. Fender Jazz Bass Strings Replacement: step 4, image 1 of 2 Fender Jazz Bass Strings Replacement: step 4, image 2 of 2
    • Insert the end of the string with no knob on the bottom through the bridge first.
    • Pull each string through to the top of the neck.
  5. Fender Jazz Bass Strings Replacement: step 5, image 1 of 1
    • Insert the strings into the indentations on the nut.
    • Wrap the strings around the tuning pegs about two times.
  6. Fender Jazz Bass Strings Replacement: step 6, image 1 of 2 Fender Jazz Bass Strings Replacement: step 6, image 2 of 2
    • Tighten the tuning pegs until the bass is in tune.
    • The standard tuning for a bass is E A D G.
    • You will have excess string hanging off the pegs of the bass.
Finish Line
Matthew Caldera
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 18
All Time: 494
