Felco Gartenschere - Pruners Disassembly
  1. Felco Gartenschere - Pruners Disassembly, Various types available: step 1, image 1 of 1
    • There are several types - e.g. also for left-handers, here a Felco Nr 4 is shown.
  2. Felco Gartenschere - Pruners Disassembly, Release mother: step 2, image 1 of 1
    • First, the upper nut SW 13 is released, then the scissors is turned over.
    • The spring can be easily removed.
  3. Felco Gartenschere - Pruners Disassembly, Release screw from below: step 3, image 1 of 1
    • Now the hinge screw can be unscrewed. Here SW 14 is used Next to it lies the spring and the lock nut.
    • Now the scissors can be completely disassembled.
    • The blade is pinned with three bolts in the handle half and usually dissolves easily.
  4. Felco Gartenschere - Pruners Disassembly, The items: step 4, image 1 of 1
    • The scissors are disassembled. We see the pivot nut, the hinge screw, the spring, the two handles and the blade.
    • The blade is ground on one side. Sharpen the beveled edge with about 15 degrees, only deburr the straight edge with a maximum of 5 degrees.
    • The parts should be free from rust and freshly oiled or greased.
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
205,513 Reputation
250 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,152 Guides authored
2 Comments
Does the fixed bolt need Locktight or thread locker applied to its thread to stop it coming loose in operation?
Nicholas Little - Reply
I did not use a thread locker and ist works until today.
VauWeh -
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 43
All Time: 2,188
