Epson Stylus Photo 1400 Ink cartridge replacement
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: step 1, image 1 of 2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: step 1, image 2 of 2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: step 2, image 1 of 2 Epson Stylus Photo 1400 Ink cartridge replacement: step 2, image 2 of 2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: step 3, image 1 of 2 Epson Stylus Photo 1400 Ink cartridge replacement: step 3, image 2 of 2
    • Close cartridge cover.
    • Close cover of the printer.
2 other people completed this guide.
Larry Huang
1,004 Reputation
4 Guides authored
Cal Poly, Team 17-11, Regan Fall 2011 Member of Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Members
12 Guides authored
5 Comments
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Reply
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Reply
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Reply
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - Reply
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - Reply
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 26
All Time: 10,086
