Ematic FunTab 2 Battery Replacement
  1. Ematic FunTab 2 Battery Replacement, Battery: step 1, image 1 of 2 Ematic FunTab 2 Battery Replacement, Battery: step 1, image 2 of 2
    • Pry open the Ematic FunTab 2 using the plastic opening tool.
  2. Ematic FunTab 2 Battery Replacement: step 2, image 1 of 1
    • Remove tape from the LCD connector.
  3. Ematic FunTab 2 Battery Replacement: step 3, image 1 of 2 Ematic FunTab 2 Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Flip up the retaining tab (the black bar on the connector), then pull LCD connector with tweezers. Be careful not to damage the LCD connector.
  4. Ematic FunTab 2 Battery Replacement: step 4, image 1 of 3 Ematic FunTab 2 Battery Replacement: step 4, image 2 of 3 Ematic FunTab 2 Battery Replacement: step 4, image 3 of 3
    • Now remove battery by putting the spudger between the battery and the LCD display and prying apart.
    • Be careful when prying the battery from the display. Wiggle the spudger if necessary.
  5. Ematic FunTab 2 Battery Replacement: step 5, image 1 of 1
    • Remove tape from the yellow, red, and black wires connecting the battery to the LCD.
  6. Ematic FunTab 2 Battery Replacement: step 6, image 1 of 3 Ematic FunTab 2 Battery Replacement: step 6, image 2 of 3 Ematic FunTab 2 Battery Replacement: step 6, image 3 of 3
    • Disconnect the yellow, red, and black wires from the motherboard.
    • You will need to solder these wires back after completing the battery replacement. Here is a link on how to solder How To Solder and Desolder Connections.
  7. Ematic FunTab 2 Battery Replacement: step 7, image 1 of 1
    • Now remove battery. The battery should still be pried from the LCD display, if not pry it again.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,423
