Electrohome EAAC475 Projector Lens Replacement
  1. Electrohome EAAC475 Projector Lens Replacement, Battery: step 1, image 1 of 2 Electrohome EAAC475 Projector Lens Replacement, Battery: step 1, image 2 of 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Projector Lens Replacement: step 2, image 1 of 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Projector Lens Replacement, Projector Lens: step 3, image 1 of 1
    • Slowly and carefully move one side away from another without detaching anything on the device.
  4. Electrohome EAAC475 Projector Lens Replacement: step 4, image 1 of 1
    • Detach the projector.
  5. Electrohome EAAC475 Projector Lens Replacement: step 5, image 1 of 2 Electrohome EAAC475 Projector Lens Replacement: step 5, image 2 of 2
    • Unplug the projector's connector from the circuit board.
  6. Electrohome EAAC475 Projector Lens Replacement: step 6, image 1 of 1
    • Take off the rubber ring.
  7. Electrohome EAAC475 Projector Lens Replacement: step 7, image 1 of 3 Electrohome EAAC475 Projector Lens Replacement: step 7, image 2 of 3 Electrohome EAAC475 Projector Lens Replacement: step 7, image 3 of 3
    • Using a metal spudger, pry into the crease until it separates enough to slip the spudger between the pieces.
    • Slide the tool along the crease to separate.
  8. Electrohome EAAC475 Projector Lens Replacement: step 8, image 1 of 1
    • Take the lens out of the projector.
  9. Electrohome EAAC475 Projector Lens Replacement: step 9, image 1 of 1
    • Separate the lens and the gear by unscrewing the gear.
Sterling Fulk
264 Reputation
2 Guides authored
IUPUI, Team 2-1, Harley Spring 2016 Member of IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 348
