Electrohome EAAC475 Button Replacement
  1. Electrohome EAAC475 Button Replacement, Battery: step 1, image 1 of 2 Electrohome EAAC475 Button Replacement, Battery: step 1, image 2 of 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Button Replacement: step 2, image 1 of 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Button Replacement, Buttons: step 3, image 1 of 2 Electrohome EAAC475 Button Replacement, Buttons: step 3, image 2 of 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Button Replacement: step 4, image 1 of 3 Electrohome EAAC475 Button Replacement: step 4, image 2 of 3 Electrohome EAAC475 Button Replacement: step 4, image 3 of 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Button Replacement: step 5, image 1 of 2 Electrohome EAAC475 Button Replacement: step 5, image 2 of 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
Sohail Khatri
201 Reputation
2 Guides authored
IUPUI, Team 2-1, Harley Spring 2016 Member of IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 242
