Eclipse MTE28VGM Motherboard Replacement
  1. Eclipse MTE28VGM  Motherboard Replacement, Motherboard: step 1, image 1 of 3 Eclipse MTE28VGM  Motherboard Replacement, Motherboard: step 1, image 2 of 3 Eclipse MTE28VGM  Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM  Motherboard Replacement: step 2, image 1 of 3 Eclipse MTE28VGM  Motherboard Replacement: step 2, image 2 of 3 Eclipse MTE28VGM  Motherboard Replacement: step 2, image 3 of 3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM  Motherboard Replacement: step 3, image 1 of 3 Eclipse MTE28VGM  Motherboard Replacement: step 3, image 2 of 3 Eclipse MTE28VGM  Motherboard Replacement: step 3, image 3 of 3
    • Using the screwdriver, remove the four 4.8 mm Phillips head J00 screws at each corner of the motherboard.
    • Remove the motherboard from the front plastic cover and screen. Replace the old motherboard with the new motherboard.
Finish Line
DELETED
252 Reputation
2 Guides authored
IUPUI, Team 2-1, Harley Fall 2016 Member of IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 208
