Eclipse 180BL Battery Replacement
  1. Eclipse 180BL Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
  2. Eclipse 180BL Battery Replacement: step 2, image 1 of 2 Eclipse 180BL Battery Replacement: step 2, image 2 of 2
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
  3. Eclipse 180BL Battery Replacement: step 3, image 1 of 3 Eclipse 180BL Battery Replacement: step 3, image 2 of 3 Eclipse 180BL Battery Replacement: step 3, image 3 of 3
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
  4. Eclipse 180BL Battery Replacement: step 4, image 1 of 1
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
3 other people completed this guide.
Thomas Schwarz
499 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 24
All Time: 1,369
