ESGE Magic Wand - Bamix blocked shaft repair
  1. ESGE Magic Wand - Bamix blocked shaft repair, Remove top cover: step 1, image 1 of 3 ESGE Magic Wand - Bamix blocked shaft repair, Remove top cover: step 1, image 2 of 3 ESGE Magic Wand - Bamix blocked shaft repair, Remove top cover: step 1, image 3 of 3
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • Unplug the power cord and remove the cutter blade.
    • The top cover is fastened with two Torx TR10 security screws. These screws are different from normal Torx screws: they are equipped with a center pin. Use the right bit or screwdriver with center hole.
    • Remove two Torx TR10 screws.
    • Carefully lift off the cover. It is latched at the front.
  2. ESGE Magic Wand - Bamix blocked shaft repair: step 2, image 1 of 3 ESGE Magic Wand - Bamix blocked shaft repair: step 2, image 2 of 3 ESGE Magic Wand - Bamix blocked shaft repair: step 2, image 3 of 3
    • This is what it looks like under the cover.
    • Slide out the two buttons and the small circuit board. The buttons are only snapped in.
  3. ESGE Magic Wand - Bamix blocked shaft repair: step 3, image 1 of 2 ESGE Magic Wand - Bamix blocked shaft repair: step 3, image 2 of 2
    • The handle is fastened with a Torx T8 machine screw and a Torx T8 plastic screw. You will need a long screwdriver.
    • Remove two Torx T8 screws.
  4. ESGE Magic Wand - Bamix blocked shaft repair: step 4, image 1 of 2 ESGE Magic Wand - Bamix blocked shaft repair: step 4, image 2 of 2
    • Unclip the handle from one side.
    • Unthread the cable, the buttons and the board.
    • The motor ist exposed. However, it is not yet completely accessible, since the lower plastic housing part cannot yet be slid over the bell. The bell must first be removed.
  5. ESGE Magic Wand - Bamix blocked shaft repair: step 5, image 1 of 3 ESGE Magic Wand - Bamix blocked shaft repair: step 5, image 2 of 3 ESGE Magic Wand - Bamix blocked shaft repair: step 5, image 3 of 3
    • First try If the bell can be unscrewed. It is fastened with a left-hand thread, so turn it in the "wrong direction", clockwise, to loosen it.
    • Pull on the knife to remove it
    • The bell sits probably quite tight, as it should not come loose during normal operation. When reassembling, glue it in place with a few drops of fluid threadlocker, if needed.
    • If it does not come off easily, then slide the lower plastic part towards the bell and clamp the motor in a vice. Do not tighten the vice very much, the motor is sensitive.
    • Use a long screwdriver as a lever between the bell and the shaft. Then carefully unscrew the bell. Reminder: the wrong way round, i.e. clockwise.
    • Pay attention to the washer between the shaft and the bell, do not lose it.
  6. ESGE Magic Wand - Bamix blocked shaft repair: step 6, image 1 of 1
    • Pull off the lower case over the shaft.
  7. ESGE Magic Wand - Bamix blocked shaft repair, Blocked shaft repair: step 7, image 1 of 2 ESGE Magic Wand - Bamix blocked shaft repair, Blocked shaft repair: step 7, image 2 of 2
    • Using a Torx T15 screwdriver unscrew the two screws securing the flange of the shaft to the motor.
    • Seperate the flange including the shaft from the motor.
  8. ESGE Magic Wand - Bamix blocked shaft repair: step 8, image 1 of 3 ESGE Magic Wand - Bamix blocked shaft repair: step 8, image 2 of 3 ESGE Magic Wand - Bamix blocked shaft repair: step 8, image 3 of 3
    • The shaft can be pushed out of the sleeve on both ends. However, the small locking pin is in the way on the lower end, and the rubber coupling on the upper end. The coupling is screwed in. Both parts can be removed.
    • The coupling must be unscrewed counterclockwise. To do this, insert a suitable tool into the groove at the upper end. If the coupling is too tight, an agent such as WD40 will help.
    • If the rubber coupling is cracked, its, the motor turns, but the shaft does not. Then you have to replace it. On this unit, the rubber coupling was fine but was screwed in very tightly. Therefore, the small locking pin for the cutting tool was pulled out with pliers.
    • When reassembling, make sure that the locking pin is firmly seated again. However, do not press it in too deeply.
  9. ESGE Magic Wand - Bamix blocked shaft repair: step 9, image 1 of 1
    • Carefully push out the shaft. You may need to use a hammer.
    • Make shure, that you do not lose the two washers.
    • There is a curved metal washer between bell and shaft...
    • ...and a flat plastic washer between rubber coupling and shaft.
    • If the surface of the shaft is no longer smooth, e.g. due to corrosion, use very fine sandpaper.
    • Thoroughly clean the inside of the sleeve and the shaft itself, e.g. with cleaning powder for the dishwasher and a pipe cleaner. Lubricate them thinly with food-grade grease before reassembly.
12 other people completed this guide.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
206,788 Reputation
255 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,166 Guides authored
26 Comments
Sehr gute Reparaturanleitung! Selber so schon zweimal an unserem Zauberstab durchgeführt und er funktioniert nach wie vor tadellos, auch nach fast 20 Jahren! Gerät und Reparatur absolut zu empfehlen!
Quattrose - Reply
Meine Welle wird immer heiß. Auseinander hatte ich den Mixer schon, aber die Info, wie man die Welle ausbaut fehlte mir. Jetzt werde ich es vermutlich morgen nochmal versuchen. Heute ist schon spät. Bin schon gespannt, wie die Welle aussieht. Anstatt 40 EUR für neuen Abtrieb. Also, ich werde berichten. Danke liebe(r) Autor/in)
Str ad - Reply
Freut mich, gutes Gelingen! Grüße, Valentin Willmann (Autor)
VauWeh - Reply
Vielen herzlichen Dank! Der Zauberstab funktioniert nun wieder. Den Stift, der das Messer hält, habe ich bei mir allerdings auch mit großem Kraft- und Zangenaufwand nicht entfernt bekommen.
Haushaltsbastler - Reply
Kann mir jemand sagen ob bei ihm Essensreste oder so etwas zu finden waren? Ich habe im SWR gesehen, dass die Keimbelastung in Pürierstäben extrem ist. Leider war kein ESGE zu sehen. Mein Stab funktioniert einwandfrei, trotzdem mache ich mir Gedanken ob ich die Welle reinigen müsste, möchte aber nicht da rum fummeln, wenn es gar nicht nötig ist.
Es wäre schön wenn mir jemand antworten würde.
Lisa - Reply
Past 24 Hours: 31
Past 7 Days: 151
Past 30 Days: 543
All Time: 12,562
