ESGE Magic Wand - Bamix blocked motor repair
  1. ESGE Magic Wand - Bamix blocked motor repair, Remove top cover: step 1, image 1 of 3 ESGE Magic Wand - Bamix blocked motor repair, Remove top cover: step 1, image 2 of 3 ESGE Magic Wand - Bamix blocked motor repair, Remove top cover: step 1, image 3 of 3
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • Unplug the power cord and remove the cutter blade.
    • The top cover is fastened with two Torx TR10 security screws. These screws are different from normal Torx screws: they are equipped with a center pin. Use the right bit or screwdriver with center hole.
    • Remove two Torx TR10 screws.
    • Carefully lift off the cover. It is latched at the front.
  2. ESGE Magic Wand - Bamix blocked motor repair: step 2, image 1 of 3 ESGE Magic Wand - Bamix blocked motor repair: step 2, image 2 of 3 ESGE Magic Wand - Bamix blocked motor repair: step 2, image 3 of 3
    • This is what it looks like under the cover.
    • Slide out the two buttons and the small circuit board. The buttons are only snapped in.
  3. ESGE Magic Wand - Bamix blocked motor repair: step 3, image 1 of 2 ESGE Magic Wand - Bamix blocked motor repair: step 3, image 2 of 2
    • The handle is fastened with a Torx T8 machine screw and a Torx T8 plastic screw. You will need a long screwdriver.
    • Remove two Torx T8 screws.
  4. ESGE Magic Wand - Bamix blocked motor repair: step 4, image 1 of 2 ESGE Magic Wand - Bamix blocked motor repair: step 4, image 2 of 2
    • Unclip the handle from one side.
    • Unthread the cable, the buttons and the board.
    • The motor ist exposed. However, it is not yet completely accessible, since the lower plastic housing part cannot yet be slid over the bell. The bell must first be removed.
  5. ESGE Magic Wand - Bamix blocked motor repair: step 5, image 1 of 3 ESGE Magic Wand - Bamix blocked motor repair: step 5, image 2 of 3 ESGE Magic Wand - Bamix blocked motor repair: step 5, image 3 of 3
    • First try If the bell can be unscrewed. It is fastened with a left-hand thread, so turn it in the "wrong direction", clockwise, to loosen it.
    • Pull on the knife to remove it
    • The bell sits probably quite tight, as it should not come loose during normal operation. When reassembling, glue it in place with a few drops of fluid threadlocker, if needed.
    • If it does not come off easily, then slide the lower plastic part towards the bell and clamp the motor in a vice. Do not tighten the vice very much, the motor is sensitive.
    • Use a long screwdriver as a lever between the bell and the shaft. Then carefully unscrew the bell. Reminder: the wrong way round, i.e. clockwise.
    • Pay attention to the washer between the shaft and the bell, do not lose it.
  6. ESGE Magic Wand - Bamix blocked motor repair: step 6, image 1 of 1
    • Pull off the lower case over the shaft.
  7. ESGE Magic Wand - Bamix blocked motor repair, Motor replace: step 7, image 1 of 2 ESGE Magic Wand - Bamix blocked motor repair, Motor replace: step 7, image 2 of 2
    • Using a Torx T15 screwdriver unscrew the two screws securing the flange of the shaft to the motor.
    • Seperate the flange including the shaft from the motor.
  8. ESGE Magic Wand - Bamix blocked motor repair: step 8, image 1 of 3 ESGE Magic Wand - Bamix blocked motor repair: step 8, image 2 of 3 ESGE Magic Wand - Bamix blocked motor repair: step 8, image 3 of 3
    • Desolder the red and the white wire. These wires are thin and delicate, don't break them.
    • The motor remains.
  9. ESGE Magic Wand - Bamix blocked motor repair, ESGE Magic Wand - Bamix blocked motor repair: step 9, image 1 of 2 ESGE Magic Wand - Bamix blocked motor repair, ESGE Magic Wand - Bamix blocked motor repair: step 9, image 2 of 2
    • The rotor is easier to remove and reinstall later when the carbons are pushed back.
    • Desolder the connections to both carbons.
    • The contact strips are delicate and cannot be bent open and closed often, work very gently.
    • Very carefully bend both contact strips open so that the coil springs are free and the carbons can be pushed back.
  10. ESGE Magic Wand - Bamix blocked motor repair: step 10, image 1 of 2 ESGE Magic Wand - Bamix blocked motor repair: step 10, image 2 of 2
    • Using a Torx T15 screwdriver remove the two long screws keeping the motor together.
  11. ESGE Magic Wand - Bamix blocked motor repair: step 11, image 1 of 1
    • Carefully pull out the upper motor shield including the carbons.
  12. ESGE Magic Wand - Bamix blocked motor repair: step 12, image 1 of 1
    • Carefully pull out the bottom motor shield.
    • Remove the rotor. If it is stuck tap it carefully out using a hammer.
    • Take care of the two washers located on the top and the bottom of the motor shaft.
    • This motor was heavily rusted and dirty inside. All sliding surfaces, the contact surfaces on the commutator (where the carbons rest), the rotor and the armatur insides were cleaned with fine sandpaper. The bearings were lubricated with silicone oil. After reassembly, the motor ran as it did on the first day.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
206,786 Reputation
255 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,165 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 104
All Time: 2,156
