Dyson Supersonic HD03 Hairdryer Filter Replacement
  1. Dyson Supersonic HD03 Hairdryer Filter Replacement, Filter: step 1, image 1 of 2 Dyson Supersonic HD03 Hairdryer Filter Replacement, Filter: step 1, image 2 of 2
    • Unplug the hairdryer to avoid further hazard.
  2. Dyson Supersonic HD03 Hairdryer Filter Replacement: step 2, image 1 of 2 Dyson Supersonic HD03 Hairdryer Filter Replacement: step 2, image 2 of 2
    • Remove the dirty filter cage by twisting the filter towards the left.
    • The filter cage will be unlocked when the red dot matches the white thin circle.
    • Do not run your hairdryer without a filter cage.
  3. Dyson Supersonic HD03 Hairdryer Filter Replacement: step 3, image 1 of 1
    • Soak the filter cage in dish soap and warm water for at least 30 minutes.
    • You can leave the filter in for multiple hours or overnight if it's especially dirty.
    • Use the supplied filter cleaning brush or any other cleaning tool to vigorously scrub the soaked filter cage.
    • Be sure to remove all blockages.
  4. Dyson Supersonic HD03 Hairdryer Filter Replacement: step 5, image 1 of 1
    • Rinse and dry your filter cage.
    • Check that the filter cage is clean by holding it up to the light - you should be able to see light through it. If you can't, repeat the previous step.
  5. Dyson Supersonic HD03 Hairdryer Filter Replacement: step 6, image 1 of 2 Dyson Supersonic HD03 Hairdryer Filter Replacement: step 6, image 2 of 2
    • Insert the filter back into the filter cage and install the filter cage back onto the device.
    • The filter cage will be locked when the red dot matches the white filled circle.
Huan-Che Hsu
192 Reputation
1 Guide authored
One Comment
My Dyson hair dryer has quitting every 30 seconds - apparently overheating. It was very easy to remove the filter cage and wipe the filter clean. Problem solved!
Jimjar - Reply
Past 24 Hours: 6
Past 7 Days: 17
Past 30 Days: 64
All Time: 4,064
