Dyson Cinetic Big Ball Animal Upright Filter Replacement
  1. Dyson Cinetic Big Ball Animal Upright Filter Replacement, Filter: step 1, image 1 of 1
    • Start on the left side of the Dyson Ball.
  2. Dyson Cinetic Big Ball Animal Upright Filter Replacement: step 2, image 1 of 1
    • Remove the center 18mm screw from the Dyson Ball, then remove the covering.
  3. Dyson Cinetic Big Ball Animal Upright Filter Replacement: step 3, image 1 of 1
    • Next, remove the upper right 18mm screw along the perimeter of the circle.
  4. Dyson Cinetic Big Ball Animal Upright Filter Replacement: step 4, image 1 of 1
    • Continuing clockwise along the path, remove the next 18mm screw.
  5. Dyson Cinetic Big Ball Animal Upright Filter Replacement: step 5, image 1 of 1
    • Remove the next 18mm screw at the lower edge of the circle.
  6. Dyson Cinetic Big Ball Animal Upright Filter Replacement: step 6, image 1 of 1
    • Then remove the final 18mm screw in the center. Once these have all been unscrewed, remove the filter with the cover. The filter and the cover should be attached to each other.
  7. Dyson Cinetic Big Ball Animal Upright Filter Replacement: step 7, image 1 of 1
    • Gently unclip the cover from the filter.
  8. Dyson Cinetic Big Ball Animal Upright Filter Replacement: step 8, image 1 of 1
    • This is how it should look once the covering has been removed.
To reassemble your device, follow these instructions in reverse order. The Dyson has two filters, so if the problem has not been resolved, you may have to repeat this process on the other side.
8 other people completed this guide.
Karla Sunjara
891 Reputation
5 Guides authored
Cal Poly, Team S13-G1, Banghart Winter 2017 Member of Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
3 Members
10 Guides authored
4 Comments
Can this filter be washed?
mariabrooke0828 - Reply
No it's not a washable filter and is supposed to last the life of the machine - hmm… still going to get clogged with fine dust though so yif contact Dyson! They don't last and the increased clogging can reduce the life of the motor.
Scott -
Can you buy a replacement filter?? Thank you.
Lori Turner - Reply
I’ve bought a second hand dyson big ball cleaner. It’s stinks of dogs. How can I take it apart and clean it?
Joyce haras - Reply
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 183
All Time: 31,113
