Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement
  1. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement, Canister Unlocking Mechanism Spring: step 1, image 1 of 1
    • If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
  2. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: step 2, image 1 of 1
    • Locate the spring in the small opening between the handle and ball of the vacuum body.
  3. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Pull out the spring by carefully inserting tweezers into the opening.
    • Carefully remove the spring.
Allison Turnbaugh
213 Reputation
2 Guides authored
Cal Poly, Team 9-5, Banghart Winter 2017 Member of Cal Poly, Team 9-5, Banghart Winter 2017
CPSU-BANGHART-W17S9G5
3 Members
18 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 33
All Time: 2,381
