Page 1 of 1
Dropping your Mac's heat levels
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Unsatisfactory Images
This guide has low-quality images. Pictures need to be either re-edited or re-taken.
Markup Problems
This guide has markup that is either not properly set or is missing from some images.
User-Contributed Guide
This guide is not managed by iFixit staff.
So, if you own a Mac, you might be aware of how hot these computers get, but they're REALLY powerful. This is not permenant, but should work to control heat for a little bit until you have to replace the pads later on because the adhesive will wear out
- Author: nick
- Time required: 5-10 munites
- Difficulty: Very easy
By looking at this guide, you can drop your macs heat levels and add some ergonomic help to it.
The only advice i have is use heat tolorant ones
Mine dropped from 180 at the most to 122 degrees or less.
Just be careful where these go on the computer. However,on the unibodys like I used to do this, DONT put them on the factory pads, they will break and need to be glued on or something.( I learned that the hard way)
Heck,this may even fix broken pad issues
- View:
- Paginated
- Full width
This guide has been completed 0 times.
Page 1 of 1
