Dreamcast CMOS battery Replacement
User-Contributed Guide
This guide is not managed by iFixit staff.
Dreamcast clock always having to be reset? Time to replace your CMOS
  • Author: Lukas
  • Difficulty: Moderate
  • Add Note x
When a Dreamcast ask for time and date every time you power on your system, your CMOS battery is dead. This guide shows how to replace the CMOS battery.
first image
Add Note Edit Step 1 — Top Cover  ¶
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • The fourth screw is hidden under the expansion bay if it has not already been removed.
first image
Add Note Edit Step 2  ¶
  • Be careful that the internal components do not topple out.
  • Flip the console topside up.
  • Remove the top cover of the chassis by gently lifting the upper portion of the console.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Controller Port  ¶
  • Be gentle with the white controller cable as it can be a bit fragile.
  • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Remove the four 14mm Philips #02 located on the controller board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Disconnect the white fan header from the controller port
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove the controller board by lifting it up from the controller port.
first image
Add Note Edit Step 7 — Replacing CMOS Battery  ¶
  • De-solder the old CMOS battery from the controller board.
  • Note where the positive and negative terminals went.
first image
Add Note Edit Step 8  ¶
  • Solder the new battery holder to some wire
  • solder those wires to corresponding points on the controller board. Take note where the Positive and negative terminals went
first image
Add Note Edit Step 9  ¶
  • Reinsert the controller board.
  • attach the battery holder inside with some self adhesive, such as double sided foam tape
  • insert the battery into the battery holder
  • reverse the disassembly directions to reassemble your Dreamcast.
  • Once your Dreamcast is reassembled, go ahead and connect the Dreamcast to you TV or monitor and power, and reset the clock.
For more information, check out the Sega Dreamcast device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
