Dragon Touch Y88X Plus Battery Replacement
  1. Dragon Touch Y88X Plus Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Battery Replacement: step 2, image 1 of 2 Dragon Touch Y88X Plus Battery Replacement: step 2, image 2 of 2
    • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
    • Carefully peel the old battery from the adhesive using your iFixit pry tool.
    • Be very cautious not to puncture the battery if yours has expanded . If the battery is swollen, read the article on What to do with a swollen battery for assistance.
  3. Dragon Touch Y88X Plus Battery Replacement: step 3, image 1 of 2 Dragon Touch Y88X Plus Battery Replacement: step 3, image 2 of 2
    • Use a soldering iron to disconnect each connector individually from the motherboard.
  4. Dragon Touch Y88X Plus Battery Replacement: step 4, image 1 of 1
    • Remove any adhesive from the battery.
    • Remove the battery.
2 other people completed this guide.
Bavly Aziz
195 Reputation
1 Guide authored
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 99
