Dragon Touch A1x Plus Cameras Replacement
  1. Dragon Touch A1x Plus Cameras Replacement, Battery: step 1, image 1 of 1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Cameras Replacement: step 2, image 1 of 2 Dragon Touch A1x Plus Cameras Replacement: step 2, image 2 of 2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Cameras Replacement: step 3, image 1 of 1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Cameras Replacement: step 4, image 1 of 1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Cameras Replacement: step 5, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Cameras Replacement: step 6, image 1 of 2 Dragon Touch A1x Plus Cameras Replacement: step 6, image 2 of 2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
  7. Dragon Touch A1x Plus Cameras Replacement, Cameras: step 7, image 1 of 2 Dragon Touch A1x Plus Cameras Replacement, Cameras: step 7, image 2 of 2
    • Remove black tape holding the cameras to the motherboard.
  8. Dragon Touch A1x Plus Cameras Replacement: step 8, image 1 of 2 Dragon Touch A1x Plus Cameras Replacement: step 8, image 2 of 2
    • Use your fingernail to flip up the small locking flap on the ZIF connector.
    • Pull the ribbon cable from the ZIF connector.
  9. Dragon Touch A1x Plus Cameras Replacement: step 9, image 1 of 1
    • Remove the front camera from the device using your fingers.
  10. Dragon Touch A1x Plus Cameras Replacement: step 10, image 1 of 2 Dragon Touch A1x Plus Cameras Replacement: step 10, image 2 of 2
    • Melt the glue holding the rear camera in place using a hair dryer.
    • Insert the metal spludger under the rear camera and pry it free from the device.
Josh Null
313 Reputation
3 Guides authored
IUPUI, Team S5-G5, Baechle Spring 2018 Member of IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 170
