Dodge Durango 2004 Tail Light Bulb Replacement
  1. Dodge Durango 2004 Tail Light Bulb Replacement, Dodge Durango 2004 Tail Light Bulb: step 1, image 1 of 2 Dodge Durango 2004 Tail Light Bulb Replacement, Dodge Durango 2004 Tail Light Bulb: step 1, image 2 of 2
    • Open the car's trunk.
  2. Dodge Durango 2004 Tail Light Bulb Replacement: step 2, image 1 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 2, image 2 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 2, image 3 of 3
    • Pry both caps out using a spudger.
  3. Dodge Durango 2004 Tail Light Bulb Replacement: step 3, image 1 of 1
    • Carefully pull the tail light towards yourself to gain access to the wiring.
    • Do not pull the tail light too far. It is still connected to the wires and moving it too far may damage them.
  4. Dodge Durango 2004 Tail Light Bulb Replacement: step 4, image 1 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 4, image 2 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 4, image 3 of 3
    • Locate the connector and pull the orange safety pin out.
    • After the safety pin is out, pull on the connector plug to separate it from the tail light.
  5. Dodge Durango 2004 Tail Light Bulb Replacement: step 5, image 1 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 5, image 2 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 5, image 3 of 3
    • Remove the three Torx 15 screws that are holding the bulb carrier in place.
  6. Dodge Durango 2004 Tail Light Bulb Replacement: step 6, image 1 of 2 Dodge Durango 2004 Tail Light Bulb Replacement: step 6, image 2 of 2
    • Remove the bulb holder piece from the tail light by gently pulling it up.
  7. Dodge Durango 2004 Tail Light Bulb Replacement: step 7, image 1 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 7, image 2 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 7, image 3 of 3
    • Remove the defective bulb by pulling it up.
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 30
All Time: 966
