Dissasembling Nokia 8290 Charging Port
  1. Dissasembling Nokia 8290 Charging Port, Front Cover: step 1, image 1 of 3 Dissasembling Nokia 8290 Charging Port, Front Cover: step 1, image 2 of 3 Dissasembling Nokia 8290 Charging Port, Front Cover: step 1, image 3 of 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: step 2, image 1 of 3 Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: step 2, image 2 of 3 Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: step 2, image 3 of 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Dissasembling Nokia 8290 Charging Port: step 3, image 1 of 3 Dissasembling Nokia 8290 Charging Port: step 3, image 2 of 3 Dissasembling Nokia 8290 Charging Port: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the indicated part.
    • The part is black with six metal connectors. Its approximate dimensions are 12.3 mm x 8.4 mm x 8.2 mm.
  4. Dissasembling Nokia 8290 Charging Port: step 4, image 1 of 3 Dissasembling Nokia 8290 Charging Port: step 4, image 2 of 3 Dissasembling Nokia 8290 Charging Port: step 4, image 3 of 3
    • There is another part located directly underneath the part removed in the previous step. Use tweezers to remove this part as well.
    • The part is black with four rectangular spaces in the bottom. Its approximate dimensions are 10.4 mm x 6.6 mm x 4.5 mm.
  5. Dissasembling Nokia 8290 Charging Port: step 5, image 1 of 3 Dissasembling Nokia 8290 Charging Port: step 5, image 2 of 3 Dissasembling Nokia 8290 Charging Port: step 5, image 3 of 3
    • After removing the two parts, locate the charging port.
    • Use tweezers to remove the charging port.
Parker Niebauer
7 Reputation
6 Guides authored
Clemson, Team 15-3, Benson Fall 2012 Member of Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Members
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 418
