Dismantling HP Pavilion dv4-2040us laptop
Featured Document
  1. Dismantling HP Pavilion dv4-2040us laptop, Remove the battery: step 1, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop, Remove the battery: step 1, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop, Remove the battery: step 1, image 3 of 3
    • Place the laptop facing down with the battery upwards in your work area.
    • Remove the battery sliding the safety latch to the left.
  2. Dismantling HP Pavilion dv4-2040us laptop: step 2, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 2, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 2, image 3 of 3
    • Remove the 3, #00 Phillips screws located below the battery.
    • Loosen the #00 Phillips screw from the RAM compartment and remove the cover.
    • Loosen the retainers.
    • Remove the RAM modules.
  3. Dismantling HP Pavilion dv4-2040us laptop: step 3, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 3, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 3, image 3 of 3
    • Remove the 2, #00 Phillips screws that secure the Hard Drive and the Wi-Fi card cover.
    • Remove the cover and unplug the 2 plugs that connect the antenna to the Wi-Fi card.
    • Remove the 2 screws and take the Wi-Fi card apart.
  4. Dismantling HP Pavilion dv4-2040us laptop: step 4, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 4, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 4, image 3 of 3
    • Unscrew the 3, #2 Phillips screws.
    • Now, use the plastic protector to pull the hard drive to the left.
    • Tilt the hard drive raising its right side.
    • Remove the hard drive.
  5. Dismantling HP Pavilion dv4-2040us laptop, Remove the DVD unit.: step 5, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop, Remove the DVD unit.: step 5, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop, Remove the DVD unit.: step 5, image 3 of 3
    • Remove the WWAN card screw.
    • Push upwards the DVD unit safety latch.
    • The DVD unit should slide out. Remove it.
  6. Dismantling HP Pavilion dv4-2040us laptop: step 6, image 1 of 2 Dismantling HP Pavilion dv4-2040us laptop: step 6, image 2 of 2
    • Remove the 3 upper left corner screws.
    • Now, remove the 2 lower left corner screws.
  7. Dismantling HP Pavilion dv4-2040us laptop: step 7, image 1 of 2 Dismantling HP Pavilion dv4-2040us laptop: step 7, image 2 of 2
    • Remove the 3 upper right corner screws.
    • Remove the 4 lower right corner screws.
  8. Dismantling HP Pavilion dv4-2040us laptop: step 8, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 8, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 8, image 3 of 3
    • Turn the laptop and open it.
    • Use plastic picks to partially separate the plastic surrounding the keyboard.
  9. Dismantling HP Pavilion dv4-2040us laptop: step 9, image 1 of 2 Dismantling HP Pavilion dv4-2040us laptop: step 9, image 2 of 2
    • Take the keyboard partially out of its place, first from the top, then from the bottom of the keyboard.
    • Push both sides of the keyboard to free the ribbon cable retainers.
  10. Dismantling HP Pavilion dv4-2040us laptop: step 10, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 10, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 10, image 3 of 3
    • Remove the 2 screws under the keyboard, located in the lower left corner.
    • Remove the 2 screws that were covered by the DVD unit.
    • Remove the keyboard plastic cover completely.
  11. Dismantling HP Pavilion dv4-2040us laptop: step 11, image 1 of 1
    • Before tearing the plastic surrounding the keyboard, remove the ribbon cable holding it in place.
  12. Dismantling HP Pavilion dv4-2040us laptop: step 12, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 12, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 12, image 3 of 3
    • Take out the Wi-Fi antenna cable and remove the label.
  13. Dismantling HP Pavilion dv4-2040us laptop: step 13, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 13, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 13, image 3 of 3
    • Push both ends of the screen cable using a tool until it's disconnected.
    • Do the same with the ribbon cable located in the far right side of the screen.
  14. Dismantling HP Pavilion dv4-2040us laptop: step 14, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 14, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 14, image 3 of 3
    • Unplug the speakers power cable.
    • Remove the 3 screws that secure the speakers.
    • Remove the speakers and the 2 screws that hold the right side of the screen in place.
  15. Dismantling HP Pavilion dv4-2040us laptop: step 15, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 15, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 15, image 3 of 3
    • Remove the screen.
    • Remove the ribbon cable that connects to the on/off button.
    • Remove the ribbon cable that connects the touchpad.
  16. Dismantling HP Pavilion dv4-2040us laptop: step 16, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 16, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 16, image 3 of 3
    • Remove the 3 screws under the screen bezel.
    • Remove the cable completely.
    • Use a plastic pick to remove the plastic that wraps the side of the laptop.
  17. Dismantling HP Pavilion dv4-2040us laptop: step 17, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 17, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 17, image 3 of 3
    • Remove the lateral card.
    • Remove the tape and the power cable from the fan cooler.
    • Put away the cable.
  18. Dismantling HP Pavilion dv4-2040us laptop: step 18, image 1 of 2 Dismantling HP Pavilion dv4-2040us laptop: step 18, image 2 of 2
    • Remove the screw that holds the motherboard in place.
    • Now remove the 2 lateral screws, use a flat head screwdriver.
    • Remove the cable located in lower right corner of the laptop.
  19. Dismantling HP Pavilion dv4-2040us laptop: step 19, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 19, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 19, image 3 of 3
    • Put the clock battery out of the way.
    • With a flat head screwdriver, remove the power cable located at the upper left side of the motherboard.
    • Remove the motherboard from it's place and turn it over.
  20. Dismantling HP Pavilion dv4-2040us laptop: step 20, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 20, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 20, image 3 of 3
    • Using your hand or a pair of pliers, remove the lint.
    • Use a screwdriver to lock the fan and prevent it to move while you are cleaning it.
    • Remove the 2 screws that hold the fan to the chassis of the laptop.
  21. Dismantling HP Pavilion dv4-2040us laptop: step 21, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 21, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 21, image 3 of 3
    • Using a #000 Phillips screwdriver, remove the 4 screws that close the fan housing.
    • With a small brush or a toothbrush, remove the dust. BE CAREFUL: the fan blades are VERY fragile, do not apply too much force with your fingers.
    • Close and screw the cooling fan housing. You can see the fan requires 5 volts, 1.55 watts and a 2 pin cable in order to work.
  22. Dismantling HP Pavilion dv4-2040us laptop: step 22, image 1 of 2 Dismantling HP Pavilion dv4-2040us laptop: step 22, image 2 of 2
    • Loosen the 4 screws that hold the heat sink in place.
    • Remove the heat sink. DO NOT remove the thermal pads.
  23. Dismantling HP Pavilion dv4-2040us laptop: step 23, image 1 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 23, image 2 of 3 Dismantling HP Pavilion dv4-2040us laptop: step 23, image 3 of 3
    • Use 70% or higher isopropyl alcohol and cotton or absorbent paper to damp.
    • With the damp cotton or paper, remove the old thermal paste from the CPU and wait to completely dry for 10 minutes.
    • Remove the thermal paste from the heat sink as well.
  24. Dismantling HP Pavilion dv4-2040us laptop: step 24, image 1 of 2 Dismantling HP Pavilion dv4-2040us laptop: step 24, image 2 of 2
    • Place a small amount of new thermal paste on the metallic part of the CPU.
    • Use your finger to evenly spread the exposed metal on the processor.
To reassemble your device, follow the instructions from the last to first step.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Marcos Mora
3,699 Reputation
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 58
All Time: 3,868
