Disassembling iClicker Device
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Image #1
Add Note Edit Step 1 — Disassembling iClicker Device  ¶
  • Behold the iclicker in all its interactive and educational beauty.
Image #1
Add Note Edit Step 2  ¶
  • Place the device on a flat surface, buttons facing down.
  • Remove the battery cover and the three batteries within.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Remove the two visible screws using a #00 Phillips screwdriver.
  • Oops! Don't forget a hidden third screw beneath the factory label.
  • Peel back the corner of the label to reveal the hidden screw.
  • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
  • For the more resistent iclickers, a spudger may be employed to separate the pieces.
Image #1
Add Note Edit Step 5  ¶
  • Your iclicker is now exposed for all its worth.
  • The back panel can be set aisde, as the remaining components are housed in the front panel.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Using a spudger, gently pry the battery connectors from the front panel.
Image #1
Add Note Edit Step 7  ¶
  • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
Image #1
Add Note Edit Step 8  ¶
  • The buttons can be easily removed from the front assembly sans spudger.
Next » « Previous
Popular Products
iPad 2 Bluetooth/Wi-Fi Antenna
$24.95 · 45 In stock
iPhone 4S Dock Connector
$34.95 · 50+ In stock
iPhone 3G Replacement Battery
$14.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
26 Bit Driver Kit
$19.95 · 43 In stock
