Disassembling Power Mac G4 M5183 DVD-ROM Drive
  1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 2, image 1 of 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 2, image 2 of 2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Disassembling Power Mac G4 M5183 DVD-ROM Drive: step 3, image 1 of 1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Disassembling Power Mac G4 M5183 DVD-ROM Drive: step 4, image 1 of 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: step 4, image 2 of 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: step 4, image 3 of 3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
  5. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 5, image 1 of 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 5, image 2 of 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 5, image 3 of 3
    • Remove DVD drive from the drive bay.
    • Lift the two metal tabs on the back of the shielding and remove.
    • Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
    • Slide out DVD drive.
11 other people completed this guide.
Stephen Scruggs
2,238 Reputation
2 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
25 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 11,146
