Disassembling Nokia 3560 Vibrator
  1. Disassembling Nokia 3560 Vibrator, Back Cover: step 1, image 1 of 2 Disassembling Nokia 3560 Vibrator, Back Cover: step 1, image 2 of 2
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Keypad: step 2, image 1 of 1
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Vibrator: step 3, image 1 of 2 Disassembling Nokia 3560 Vibrator: step 3, image 2 of 2
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 LCD Display: step 4, image 1 of 1
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Vibrator: step 5, image 1 of 1
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Vibrator: step 6, image 1 of 2 Disassembling Nokia 3560 Vibrator: step 6, image 2 of 2
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Vibrator: step 7, image 1 of 1
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Logic Board: step 8, image 1 of 1
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: step 9, image 1 of 2 Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: step 9, image 2 of 2
    • The orange piece is the vibrator.
    • It is not fastened by any means.
    • Remove with tweezers.
Sam Ryan
1 Reputation
8 Guides authored
Cal Poly, Team 30-39, Garner Spring 2010 Member of Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 13
All Time: 1,274
