Disassembling Macintosh IIsi Logic Board
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Author: Chris Green
  • Time required: 15 - 35 Minutes
  • Difficulty: Difficult
  • Add Note x
Like all of the other components of the Macintosh IIsi, the logic board requires no tools to remove.
Sections
Sections (continued)
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Top Case  ¶
  • Start by turning the computer around, and removing this screw:
  • There may or may not be a Phillips #0 screw here depending on whether or not the computer has ever been serviced.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Now lift these two clips, and slowly pivot the case up.
  • You can now seperate the top of the computer from the rest of the machine.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3 — Hard Drive  ¶
  • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
  • Start by pushing these two tabs out, and lifting the drive up.
  • Then, flip the drive over, and remove the connection cables.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
  • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
  • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5 — Floppy Drive  ¶
  • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
  • Push these two tabs out, and lift the drive up.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
  • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
  • This drive was manufactured by Sony in 1990.
first image
Add Note Edit Step 7 — System Fan  ¶
  • The fan recieves power from two contacts on the logic board and has no connector.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • In all of the years that I have worked on this machine, I have found no good way to remove the fan.
  • The best way to start, is to push in here on the side of the fan.
  • Being careful not to exert too much force, try to push in, and wiggle the fan outward as such. (2nd Photo)
  • You can now lift the fan all the way out, and remove it.
  • The Fan Power Contacts on the Logic Board:
first image
thumb image 1
thumb image 2
Add Note Edit Step 9 — Power Supply  ¶
  • To remove the power supply, squeeze these two tabs and lift the front up.
  • On the back of the power supply, there is a tab that also must be pressed to remove the power supply fully. You can then lift it out all the way. A firm tug may be necessary to seperate the power connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Information on the power supply:
  • It was made by Sony in 1990, and uses a 10-Pin power connector.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11 — Logic Board  ¶
  • The logic board is designed in a way, where it can be slid forward, then lifted out.
  • To remove the board, push these two tabs outward, and begin to slide the logic board away from the back (Port Side) of the computer.
  • Once the logic board clears the ports it can be lifted out.
first image
Add Note Edit Step 12  ¶
  • The Processor: 20Mhz Motorola 68030 model # MC68030RC20B
  • The Onboard RAM: 1MB Soldered the the logic board.
  • RAM Slots: 4 30-Pin DIMMs installed in pairs.
  • ROM SIMM Slot: If your computer doesn't have one if these (and it works) , it doesn't need one. If it has one, it needs it in order to boot.
  • PDS Slot: For Attaching a riser card containing a math co-processor. A PDS card can then be plugged into the riser card. PDS - Processor Direct Slot
  • Power Supply Connector: for direct connection to the power supply.
  • "VSLI" chip: This machine's equivalent of a "Northbridge" It manages RAM, PDS, and the external ports.
For more information, check out the Macintosh IIsi device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
