Disassembling Flip Video USB Port
  1. Disassembling Flip Video USB Port, Outer Shell: step 1, image 1 of 2 Disassembling Flip Video USB Port, Outer Shell: step 1, image 2 of 2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Disassembling Flip Video USB Port: step 2, image 1 of 1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Disassembling Flip Video USB Port: step 3, image 1 of 2 Disassembling Flip Video USB Port: step 3, image 2 of 2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Disassembling Flip Video USB Port: step 4, image 1 of 1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Disassembling Flip Video USB Port: step 5, image 1 of 1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Disassembling Flip Video USB Port, Circuit Board: step 6, image 1 of 1
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  7. Disassembling Flip Video USB Port: step 7, image 1 of 1
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
  8. Disassembling Flip Video USB Port: step 8, image 1 of 1
    • Disconnect the USB port cable from the back side of the circuit board.
  9. Disassembling Flip Video USB Port: step 9, image 1 of 1
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
  10. Disassembling Flip Video USB Port, USB Port: step 10, image 1 of 1
    • Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
  11. Disassembling Flip Video USB Port: step 11, image 1 of 1
    • Lift wire out of the outer shell slot.
    • The wire mount should stay attached to the wire.
  12. Disassembling Flip Video USB Port: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the spring that holds the port door shut.
    • Make sure the spring is firmly grasped by the tweezers so that it does not shoot off of the case.
  13. Disassembling Flip Video USB Port: step 13, image 1 of 1
    • Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
  14. Disassembling Flip Video USB Port: step 14, image 1 of 1
    • Remove the USB port cover.
  15. Disassembling Flip Video USB Port: step 15, image 1 of 1
    • Remove the USB slider.
  16. Disassembling Flip Video USB Port: step 16, image 1 of 1
    • Lift out the USB port slowly.
    • Since the hinge is spring loaded, be careful that no pieces fall out when the port is lifted.
Elizabeth
100 Reputation
6 Guides authored
Cal Poly, Team 26-21, Regan Spring 2010 Member of Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 4,136
