Disassembling Dell Latitude D620 Display
Missing Prerequisites
This guide is missing prerequisite guides.
User-Contributed Guide
This guide is not managed by iFixit staff.
Author:
Miguel Wong
- Time required: 30 minutes
- Difficulty: Moderate
Guide to separating the display from the body of the laptop.
Embed this guide
With the HTML code below, you can embed this guide as a small widget on your website.
Locate the notch under the cover at the top of the keyboard
Using the spudger as a lever, lift the plastic covering
Carefully remove the rest of the covering from right to left
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
Turn the laptop over again so it's right-side up
Open the display, and pull the display up and out of the laptop's body
This guide has been completed 4 times.
