Disassembling Dell Inspiron 1150 Wireless MiniPCI Card
Improper Action This guide contains images that improperly convey how to perform a specific action.
Markup Problems This guide has markup that is either not properly set or is missing from some images.
User-Contributed Guide This guide is not managed by iFixit staff.
How to locate and remove the 1150 Wireless MiniPCI Card.
Author:
Teja Time required: 10 Minutes Difficulty: Easy
The purpose of this guide is to provide guidance on how to locate and remove the 1150 Wireless MiniPCI Card.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Edit Step 1
Turn the laptop upside down and locate the panel labeled C.
Unscrew the single screw holding the cover in place.
lift up the cover and remove it to exposed the Wireless MiniPCI Card.
Using a plastic spudger or similar, gently pry the grey and black wires off. These are the antenna wires so be careful not to damage them
Gently pull the retaining clips away from the board so that the board pops up.
For more information, check out the Dell Inspiron 1150
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Disassembling Dell Inspiron 1150 Wireless MiniPCI Card. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 0 times.
