Disassembling Dell Inspiron 1150 Modem Card
User-Contributed Guide
This guide is not managed by iFixit staff.
The purpose of this guide is to provide guidance to replace the modem card.
  • Author: Lauren
  • Time required: 5 mintues
  • Difficulty: Easy
  • Add Note x
This guide will demonstrate how to replace the Modem card.
Sections
Tools
first image
thumb image 1
thumb image 2
thumb image 3
  • With the laptop placed upside down, locate the "Battery Release" button. It has a little "Padlock" symbol next to it.
  • Slide the "Battery Release" button toward the padlock symbol and hold it there. Note:- The button is spring loaded and will return if released.
  • Gently extract the battery from the side of the laptop
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2 — Modem Card  ¶
  • Turn the laptop upside down and locate the panel labeled C
  • Unscrew the single screw holding the cover in place.
  • Lift up the cover and remove it to expose the Modem Card.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Locate the Modem card.
  • Remove the screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Pull tab to lift the card out of the connector on the main board.
  • Disconnect the cable attached to the left edge of the Modem card
For more information, check out the Dell Inspiron 1150 device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
