Disassembling Compaq Mini 110 Speakers
Unsatisfactory Images This guide has low-quality images. Pictures need to be either re-edited or re-taken.
User-Contributed Guide This guide is not managed by iFixit staff.
Missing Steps This guide is incomplete or missing critical steps.
Inconsistent Images This guide contains images that are inconsistent with prerequisites.
Improper Action This guide contains images that improperly convey how to perform a specific action.
Markup Problems This guide has markup that is either not properly set or is missing from some images.
Removing the built-in speakers.
If your sound is not functioning properly these may be the problem. Check the troubleshooting guide before proceeding.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Sections (continued) Tools
Edit Step 5
Keyboard
Remove the rubber pads located on the corners of your Compaq Mini.
There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
Edit Step 9
Hard Drive
Edit Step 11
Top Cover
Edit Step 14
Display Assembly
Pry off the top plastic cover of the display assembly.
Note: There is adhesive tape holding the cover on.
Note: The spudger may go all the way through to the screen-side of the cover. This is ok and will not damage anything.
The huge wire on the back of the screen is for both the webcam/microphone, as well as the screen.
Detach the cable from the screen. It is connected under the foil flap.
Edit Step 19
Speakers
For more information, check out the Compaq Mini 110
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Disassembling Compaq Mini 110 Speakers. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 0 times.
