Disassembling Compaq Mini 110 Screen
Unsatisfactory Images
This guide has low-quality images. Pictures need to be either re-edited or re-taken.
User-Contributed Guide
This guide is not managed by iFixit staff.
Missing Steps
Missing Steps
This guide is incomplete or missing critical steps.
Inconsistent Images
Inconsistent Images
This guide contains images that are inconsistent with prerequisites.
Improper Action
Improper Action
This guide contains images that improperly convey how to perform a specific action.
Markup Problems
Markup Problems
This guide has markup that is either not properly set or is missing from some images.
Removing the screen from the display assembly.
  • Author: alea
  • Time required: 5 minutes
  • Difficulty: Moderate
  • Add Note x
Maybe it's cracked. Maybe you brought a magnet too close to it. Either way, the screen needs replacing and here's how to do it.
Sections
first image
thumb image 1
thumb image 2
  • Find the battery and the battery tabs located on the bottom of the Compaq Mini.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Push the tabs inward and slide the battery out.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — RAM  ¶
  • Find and remove the two screws on the bottom of your Compaq Mini covering the memory compartment.
    • Note that the screws are attached to the panel.
first image
Add Note Edit Step 4  ¶
  • Push out side tabs.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5 — Keyboard  ¶
  • Remove the rubber pads located on the corners of your Compaq Mini.
  • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Unscrew all the corner screws. There are four total, one under each rubber pad.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Unscrew the screw for the bottom case located in the RAM compartment.
first image
Add Note Edit Step 8  ¶
  • Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
first image
Add Note Edit Step 9 — Hard Drive  ¶
  • Remove the three screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Pull up on the tab.
first image
Add Note Edit Step 11 — Top Cover  ¶
  • Remove the eight screws from the plastic top cover.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 12  ¶
  • Pry up the top plastic cover using a spudger.
    • Under the screen there are two tabs that need to be pushed in.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Careful lifting up the cover because the track pad is still attached.
  • Remove the cable by pulling it up.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 14 — Display Assembly  ¶
  • Take out the four screws that keep the bottom of the hinges attached to the base.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 15  ¶
  • Pry off the top plastic cover of the display assembly.
  • Note: There is adhesive tape holding the cover on.
  • Note: The spudger may go all the way through to the screen-side of the cover. This is ok and will not damage anything.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 16 — Screen  ¶
  • Remove the 4 screws keeping the screen on the plastic assembly.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 17  ¶
  • Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws
  • The last picture is of the metal connectors that attach it to the display assembly.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 18  ¶
  • The huge wire on the back of the screen is for both the webcam/microphone, as well as the screen.
  • Detach the cable from the screen. It is connected under the foil flap.
For more information, check out the Compaq Mini 110 device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
