Disassembling BlackBerry 8703e Keyboard
User-Contributed Guide
This guide is not managed by iFixit staff.
Student Guide
Student Guide
This guide is being worked on by students.
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Incorrect Bullets
Incorrect Bullets
This guide contains bullet colors that do not match markup, or improperly-used bullet types.
Unsatisfactory Images
This guide has low-quality images. Pictures need to be either re-edited or re-taken.
Incorrect Text
Incorrect Text
This guide contains steps with ambiguous, improper, duplicate, misleading, or off-topic text.
  • Add Note x
This guide describes how to disassemble a BlackBerry 8703e keyboard.
Sections
first image
thumb image 1
thumb image 2
  • Press and hold down the bottom button on the back of the device, whilst sliding down the battery cover.
  • Place the battery cover to one side.
first image
Add Note Edit Step 2  ¶
  • Insert your finger in the small notch highlighted in the photograph and remove the battery from the back of the phone.
  • Place the battery to one side.
  • The battery is not pictured.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Case  ¶
  • Place the phone screen down and use a T6 Torx Screwdriver to remove the 3 screws highlighted in the picture.
  • Carefully store the screws together where they will not be lost.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • You may need to use significant force to completely remove the back casing from the remainder of the phone.
  • Using your thumb and beginning with the notch shown in the picture at the bottom of the phone, start to separate the back casing from the phone.
  • Insert the Spudger in the separation you created. While still applying significant force with your thumb, slide the Spudger up the separation from the bottom of the phone to the top until you remove the back casing.
  • Set the back casing to the side.
first image
Add Note Edit Step 5  ¶
  • Do not separate the front casing from the rest of the phone during this step.
  • Remove the 4 screws on the back of the phone that are highlighted in the picture using a T6 Torx Screwdriver.
  • Carefully store the screws where they will not be lost
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • 2 keyboard components and a small black port protector may accidentally fall out during this step. If this happens, do not be alarmed, simply place them to the side.
  • Hold the phone with the screen facing the ground and remove the front casing from the rest of the phone.
  • The port protector is not shown in the second picture.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7 — Keyboard  ¶
  • The 2 keyboard components highlighted in the picture may fall out of the front casing but remain stuck together.
  • If the keyboard components did not fall off while removing the front casing, remove them from the front casing and place them to the side.
For more information, check out the BlackBerry 8703e device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
