Introduction
The pole of the Tobias Grau lamp had become loose; this guide documents how to tighten it again.
foot had become loose
The Parrot lamp rests on 1 foot, and it had become a bit loose recently.
To open it, first remove the five rubbre feet by gently pulling them loose.
Then unscrew 5 torx screws, and the bottom is loose
Closing is a matter of fixing the connector, and re-attaching the bottom plate. It is easiest to holde the placte vertically, place the five screws in and place the plastic washers on the inside all at the same time. Then gently close it a bit, and fix the screws.
The 3 holes for the rubber feet also fit the screws, so avoid those.
fix the rubber feet by placing them on the three holes, and gently rock them in place.
It was an easy fit of the issue; the lamp hsa ben well-desgned for repair.
